Half Wall with different heigths
Mike76
I would like to create a half wall (solid railing) that is one height on one end, and different height on the other.
I have searched all the databases and forums and found nothing on this.
Any Ideas?
1) Please fill out your Signature -- see below.
2) Not sure if this works in all the titles -- It does work in Pro.
In an elevation view, select the wall. Use one of the edit handles to reshape it.
You may also add breaks (3 key) along the edge.
It helps if we know what title (Suite, Pro etc) and version (2014, 2015 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left. Doing so makes it always available, and this info is often key to providing a good suggestion
Resources for self help:
