second floor started in the attic
maeast
It looks as though you have some or all of the walls of the upper floor set back from the walls of the lower floor, which creates a design issue with the roof on the lower floor. You need to reduce the pitch of the roof to keep its ridge below the windows on the upper floor and/or adjust the amount of setback to make it work. You may also want to consider changing the style of the roof. It looks as though the hip roof you are using gets quite complicated with your design. A gable or two may help.
Tom
