Ryan_Brown Posted January 17, 2017 Share Posted January 17, 2017 I am trying to draw a gabled roof where the peak is off center to the building but have been unable to even come close to a solution thus far. I would like consistent pitches but for one eave wall to be higher than the other pushing the peak off center. I know how to change ceiling height of a room but see no where to change a specific wall height. Any help would be greatly appreciated. Ryan (Home Designer Suite 8) Link to comment Share on other sites More sharing options...
gratepunkin Posted January 17, 2017 Share Posted January 17, 2017 your on the right track with needing to raise the ceiling height in one of the rooms you cant change wall height independently and have roof build like that in this program it all comes down to the maths see below - roof pitch same on both sides but the ceiling height in left room is taller than right 2 Link to comment Share on other sites More sharing options...
TomGriff Posted January 17, 2017 Share Posted January 17, 2017 You can also create a manual roof plane, open it, and set the baseline height to whatever you need. The height of the wall under the roof plane will adjust to suit the baseline setting. Tom 1 Link to comment Share on other sites More sharing options...
gratepunkin Posted January 17, 2017 Share Posted January 17, 2017 On 1/17/2017 at 8:41 PM, TomGriff said: You can also create a manual roof plane, open it, and set the baseline height to whatever you need. The height of the wall under the roof plane will adjust to suit the baseline setting. Tom Expand not in suite you cant Link to comment Share on other sites More sharing options...
Ryan_Brown Posted January 18, 2017 Author Share Posted January 18, 2017 Thanks Gratepunkin. The room separation and individual ceiling height was the solution. You saved a lot of time for me! Link to comment Share on other sites More sharing options...
gratepunkin Posted February 8, 2017 Share Posted February 8, 2017 excellent! Link to comment Share on other sites More sharing options...
