Keith_K Posted August 14, 2014 Share Posted August 14, 2014 ...so that I can look at two plans at the same time? I know that I seem to do things in a way that is totally different to how others might but that is just me and I seem to, somehow, always get there in the end. I am busy splitting my office block into individual office areas. At the same time I am also labelling the offices and placing desks (370 of them) and things within the offices. BUT I am doing this on two separate plans because the "furniture" plan is for illustration purposes only and I want to keep it totally separate from the main plan. Obviously I am moving internal walls around while doing the office layout and allocation and while I know that I can flip between one plan and the other (which is somewhat laborious and time consuming) I would really prefer it if I could split my screen and have the relevant sections of both plans visible at the same time so that what I do in one split section I can do immediately in the second. Is this possible or am I hoping for too much? Which wouldn't surprise me at all. Link to comment Share on other sites More sharing options...
elgreco Posted August 14, 2014 Share Posted August 14, 2014 Hi Keith I think I understand what you are trying to do. If you open both files (plans) and select Window>Tile Vertically you will have both plans side by side. A shorcut to this is to hit SHIFT-F6. I am based in the UK so it would be good to swap ideas (in Metric of course!) Rgds elgreco Link to comment Share on other sites More sharing options...
Solution Keith_K Posted August 14, 2014 Author Solution Share Posted August 14, 2014 Bloody marvellous! Thank you. That is exactly what I wanted. This must be my shortest topic yet. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 14, 2014 Share Posted August 14, 2014 2015 also allows multiple screens now , you just drag the Tab to the other monitor , though you can drag the single window out to two monitors in 2014 and below as well and still use Shift-F6 Link to comment Share on other sites More sharing options...
