belmont Posted August 10, 2014 Share Posted August 10, 2014 How do I edit the height of a bow or bay window in home designer pro? If I open the edit object screen there is no place to edit the size. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 10, 2014 Share Posted August 10, 2014 I think you may need to explode the Bay 1st? that is Dormers check the Ref. Manual M. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 10, 2014 Share Posted August 10, 2014 what version of Pro ? in newer versions you change the width/depth and height off the ground in the Bay's DBX in older versions like mine you have to do it all in Plan View ,click and Dragging the walls for width and depth and then in an elevation view drag the bottom of the wall up if it is not to go down to the foundation. Link to comment Share on other sites More sharing options...
belmont Posted August 10, 2014 Author Share Posted August 10, 2014 Didn't have any luck with the manuals. I am using Pro 2014. I am very new to the program and I don't know what DBX is. Could you explain please? Link to comment Share on other sites More sharing options...
Kbird1 Posted August 10, 2014 Share Posted August 10, 2014 sorry DBX is Dialog Box ..........a common abbreviation around here. select the bay and "open the object" either via the right click (RC) menu or with the icon on the Edit Toolbar Link to comment Share on other sites More sharing options...
belmont Posted August 10, 2014 Author Share Posted August 10, 2014 There is no place to enter any measurements into the DBX. The only way I can change the size is by manually clicking and dragging, and even then it will only let me adjust the width. Dragging the walls down or up does nothing to the height of the windows. It won't let me adjust the height anywhere that I can find. The DBX only gives me options for roof line, suppressing dimensions, and adjusting framing between windows. Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted August 10, 2014 Solution Share Posted August 10, 2014 what version of Pro ? in newer versions you change the width/depth and height off the ground in the Bay's DBX in older versions like mine you have to do it all in Plan View ,click and Dragging the walls for width and depth and then in an elevation view drag the bottom of the wall up if it is not to go down to the foundation. Sounds like 2014 has the same DBX as Pro10 or all other Older versions , so yes you have to do it in plan view ,width and depth of wall ( grab small edit handle in each case and drag out) too adjust the height off the Floor/ground you need to do that in an elevation view of the wall/window box ,select the window box and drag the bottom up as needed. edit: correction I am not sure why it makes the windows 36" high to start ,but after some playing in a test plan I discovered , that if you select the bay window , then click Next Object , it will let you edit the height and width of the Window you click to select the Bay on , this can be done in any view , on all 3 windows M. Link to comment Share on other sites More sharing options...
