wallywally Posted June 29, 2016 Share Posted June 29, 2016 Very new here. Is there a way to prevent pre existing dimensions from changing when trying to only change one size? My first learning project is a simple 2 car garage. Once I built the exterior walls to the correct size, I am trying to add two garage doors on one wall with a walk door centered between them. I have plenty of room for everything on that wall. I want the garage doors to be a specific distance from the end of the wall on both sides. It is easy enough to put them all on the wall, but when I try to change any of the dimensions between items it automatically changes the opposite exterior walls size also. Is there a way to prevent this? Link to comment Share on other sites More sharing options...
Solution wallywally Posted June 29, 2016 Author Solution Share Posted June 29, 2016 Was able to do what I need with the transform tool Link to comment Share on other sites More sharing options...
