glvsav37 Posted March 29, 2016 Share Posted March 29, 2016 Hi all...this may be a simple thing, but i can't find a solution. I'm tracing an existing blueprint to make a 3D map, and the building has a lot of walls that are on an odd angle. However, when I try and draw a wall, it 'snaps' to a certain set of angles either too shallow or to wide of what i need. Can't I unlock it and let me freely rotate the walls to the angle I need? Is it a preference that is set somewhere? thanks Edit to add: I'm using Home Designer Architectural 2017, Build 18.1.0.41 for Mac OS X Link to comment Share on other sites More sharing options...
katalyst777 Posted March 29, 2016 Share Posted March 29, 2016 I would suggest rotating the floor plan first, so that you get most of the walls at standard angles (you can have problems with wall connections if walls aren't truly parallel/perpendicular to one another) and then set the Wall Angle in the dialog itself (if you override with Control or turning off Angle Snaps, you can end up with crazy 90.1124984 angled wall nonsense that just causes a headache down the line). Link to comment Share on other sites More sharing options...
