KSmith Posted February 24, 2016 Share Posted February 24, 2016 Is it possible to set default settings globally so that they are the same for every plan? I always set my dimensions to inches, always to measure off the surface and I never want a roof or auto exterior dimensions (I just do interiors). Any thoughts? Link to comment Share on other sites More sharing options...
katalyst777 Posted February 24, 2016 Share Posted February 24, 2016 If you upgrade to the Chief Architect Premier version, you can set up templates for that.In Home Designer, just set up all your defaults, save the plan, and any time you want to start a new drawing, open the file you saved and then immediately do a File> Save As to give it a new name before drawing anything. 1 Link to comment Share on other sites More sharing options...
