ChiefEric Posted February 13, 2016 Share Posted February 13, 2016 All I'm trying to build a wall roughly 12' x 19'2" and decorate it with with columns and caps. Its starting to occur to me I might as well draw all of it on paper as either my approach is all wrong or the program is all wrong for this type of thing. I have to use exterior walls rather than landscape walls because I have to put stucco bands, caps, and stone edges on it. ( I would like to point out that leaves undesirable wall construction materials exposed in 3d view.) I am using back splashes to create the stucco bands and inner designs of the signs. I could build the wall faster than I can design this stupid sign. LOL. Anyone have any pro tips on building designed landscape walls. Link to comment Share on other sites More sharing options...
ChiefEric Posted February 13, 2016 Author Share Posted February 13, 2016 Thanks for the reply. I'm using Home Designer Pro 2016. Here's a link to the work in progress. I haven't tried soffits yet... https://www.dropbox.com/sh/1xpv0904horl8jf/AABgt809nWPi7GBC8Tm7RWD9a?dl=0 Link to comment Share on other sites More sharing options...
solver Posted February 13, 2016 Share Posted February 13, 2016 I would not bother with walls. Build everything from solids. Once done you can group everything and save it as an Architectural Block to make moving it easier. A custom countertop will accept moldings if needed. Link to comment Share on other sites More sharing options...
ChiefEric Posted February 13, 2016 Author Share Posted February 13, 2016 Oh yes the moving issue thank you for addressing that wasn't sure how to accomplish I'll look up the process. Thank you! What do you mean buy building with solids? Link to comment Share on other sites More sharing options...
solver Posted February 13, 2016 Share Posted February 13, 2016 Use shapes. Slabs, soffits, shapes from the library -- there are wedges, rounds etc that you can use -- search for "closed". 1 Link to comment Share on other sites More sharing options...
ChiefEric Posted February 14, 2016 Author Share Posted February 14, 2016 Thank you so much! Worked on it last night definitely pro tip! Link to comment Share on other sites More sharing options...
