3rd_Floor Posted July 6, 2014 Share Posted July 6, 2014 In Home Designer Suite 8, my title bars (I think that's what they're called) are thick and easy to click on. This is how I like it because I'm constantly toggling back and forth between different views of the plan I'm working on. In Pro 2015, the title bars are about half as high. Is there a way to ajust the thickness (height) of the title bars in the 2015 version? In Suite 8, it seems to be following the size that I've set in my Windows 7 personalized settings. Included is a screenhot from Suite 8 and Pro 2015 with the title bars circled in red to show the difference. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 6, 2014 Share Posted July 6, 2014 2015 uses TABBED views so it may not use your personalised setting like normal windows do , however that may change if you "undock" the Tab , ie drag it off the main window ,so it becomes it own window , same as you would do if using multiple monitors which is a new feature in 2015. Link to comment Share on other sites More sharing options...
