eganders Posted May 14, 2014 Share Posted May 14, 2014 I am using Home Designer Architectural. I have used layers in many other programs, but I am having trouble understanding how Home designer layers work. I have 2 terrain features that overlap. Since they are terrain features, I think they are considered to be on the same layer, but they don't act like it. I put in a terrain feature of a cobblestone area and later put in a terrain feature of just ground cover that I wanted underneath the cobblestone feature. That is the way it turned out, but I don't understand why. Usually in the other graphic programs I have used, the last item entered went on a layer that covered the previous item that was on a layer below and if you wanted to change it, you would have to reorder the layers. How do I determine the layer (or more probably the order) of what is on top of what? Is there a video, discussion, webinar or something that reviews this and makes this clearer? Link to comment Share on other sites More sharing options...
Solution katalyst777 Posted May 14, 2014 Solution Share Posted May 14, 2014 You might need to adjust the Height of one of your terrain features so that it is slightly more raised than the other. http://www.homedesignersoftware.com/support/article/KB-00806/ http://www.homedesignersoftware.com/support/article/KB-00864/ 2 Link to comment Share on other sites More sharing options...
eganders Posted May 14, 2014 Author Share Posted May 14, 2014 Thanks. I will try that. Link to comment Share on other sites More sharing options...
