villathalassa Posted October 9, 2015 Share Posted October 9, 2015 I need to incorporate a gas fired range which has a vertical exhaust pipe. This must go up, then turn through 45 degrees, attach to a pipe at the angle, then go back through 45 degrees to the vertical. I have tried using vertical and horizontal cylinders, but these cannot be rotated. Is there any way to do this? Link to comment Share on other sites More sharing options...
KirkClemons Posted October 9, 2015 Share Posted October 9, 2015 You might be able to model something like that in another program, such as Sketchup, then import it as a symbol if you version of the software supports Sketchup import. Custom modeling like that is a little outside the scope of the Home Designer software's capabilities or intended functionality. Link to comment Share on other sites More sharing options...
