scott_v Posted September 11, 2015 Share Posted September 11, 2015 Attached is a test plan I've been working on to try and resolve why Pro 2016 will not build a garage door header to the default size. The door is 9' wide therefore the header should be sized at 11.25, instead Pro is drawing it 8.625 inches. Any suggestions? test plan 9.10.15 .plan Link to comment Share on other sites More sharing options...
Kbird1 Posted September 11, 2015 Share Posted September 11, 2015 yes ....get a 7' garage door or raise the garage ceiling 3.5" so the beam can fit under the Top Plates...... or of course a Beam that can span that at distance without as much depth eg LVL M. Link to comment Share on other sites More sharing options...
