mbarcus Posted May 13, 2014 Share Posted May 13, 2014 see attachment.I need to get rid of the gap between the roof and the walls.The roof is like the picture all around the house.I've tried changing the wall height, but that doesn't fix the problem.Please point me in the right direction. Link to comment Share on other sites More sharing options...
mbarcus Posted May 13, 2014 Author Share Posted May 13, 2014 Home Designer Pro 2014 Link to comment Share on other sites More sharing options...
Kbird1 Posted May 13, 2014 Share Posted May 13, 2014 see old forum for replies there Link to comment Share on other sites More sharing options...
katalyst777 Posted May 14, 2014 Share Posted May 14, 2014 Just bringing over the replies from the thread on the old forum in case you had trouble finding them.http://hometalk.homedesignersoftware.com/showthread.php?19531-roof-problem In HD Pro you can simply left-click on the wall which selects the "Wall Poly Line" that then has "Handels" that you can left-click-drag to reshape the wall in a cross section or other camera view (I prefer the cross section camera view for preciseness).DJP you can drag the wall up as suggested but are the walls too low or is the roof too high ? it is ALL walls right not just the peak in the pic? perhaps lower the roof baseline height if the walls are already the correct height eg 8' stud/96"If there isn't any manual roof planes I'd probably delete the roof ,make sure my walls are setup right height and rebuilt the roof....Kbird Link to comment Share on other sites More sharing options...
