ECIDesigner Posted August 11, 2015 Share Posted August 11, 2015 Hi, I have a two part question regarding layouts and importing pdf's. I currently use Pro 2015. First - I am having problems importing a pdf onto a "layout" page. I select "import" then import the pdf file. The pdf I select only imports the lower left corner of the pdf page. It seems as if I need to change the size so that it will import the entire page. Any suggestions? Secondly, I am looking for the best way to import a floor plan and add my own notes to the plan to share with my contractor. I thought I could import a pdf of a floor plan onto a layout sheet, Then add text to the plan. Is there a better way to accomplish this? Thank you for any suggestions! Link to comment Share on other sites More sharing options...
Kbird1 Posted August 11, 2015 Share Posted August 11, 2015 I haven't tried this but I'd import to plan view , add your text notes and then send to layout . Link to comment Share on other sites More sharing options...
