SJM1986 Posted July 30, 2015 Share Posted July 30, 2015 I have a four-panel glass pocket door that opens to a patio. The panels retract/slide into a pocket on one side. How do I construct such a door? Link to comment Share on other sites More sharing options...
Kbird1 Posted July 30, 2015 Share Posted July 30, 2015 The Pocket Door in the Door Menu also works in Exterior Walls, though I am uncertain if you can make it have 4 doors ? going into one side ? haven't tried that. But you can push two Doors hard upto each other to show 4 doors. find the appropriate door in the Library , setting it to Single Door only will make it slide to one side but then you only get one Door too, so it may depend on what is more important to you to show. Pic of the Door may help someone come up with a "workaround" ..... thinking outside the box is something HD Users find they need to do sometimes. Link to comment Share on other sites More sharing options...
