LLuckham Posted July 23, 2015 Share Posted July 23, 2015 I'm trying to add a ceramic tile tub surround and haven't been able to figure out how to add tile to the wall area only over the tub. Applying tile to the entire back wall is easy. It's the end walls that I can't figure out. There doesn't seem to be an object for a tub surround that can just be places and I've not been able to figure out how to limit the tiled area to only the tub, but not the entire end walls. How is this done? New User. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 23, 2015 Share Posted July 23, 2015 if you want tile to the ceiling Use the Wall Break Tool and place a break 2-4" outside the tub , then select the wall over the tub area and change the interior wall material to the desired tile. If that doesn't work with your title or you only want tile say 2' high off tub use a Soffit (cabinet menu) and apply tile to it once you have resized it to 2'h x 3'w x1/4 thick or whatever you need to cover the area. other options may exist depending on your Title which is why its good to know what you are using... M. Link to comment Share on other sites More sharing options...
katalyst777 Posted July 28, 2015 Share Posted July 28, 2015 https://www.homedesignersoftware.com/support/article/KB-02020/importing-and-using-a-custom-bathtub-symbol.html 1 Link to comment Share on other sites More sharing options...
