Ginger Posted June 14, 2014 Share Posted June 14, 2014 Guys can someone help me with tapered peirs, see attachment. I have tried a number of ways of doing this without a result. Cheers Mark Link to comment Share on other sites More sharing options...
Elovia Posted June 14, 2014 Share Posted June 14, 2014 Mark, It appears from your photo that the piers are tapered on only one side. If true, and depending on which version of Home Designer software that you're using, you should be able to apply a wedge from the shapes library adjacent to a soffit, box, or slab object. You'll then need to apply an appropriate texture to each, and if the option is available in your software title, apply the textures with global mapping so they blend seamlessly across both objects. Hope this helps. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 14, 2014 Share Posted June 14, 2014 Nice suggestion Elovia , good to see you back on the Forum too Ginger yoru image didn't post on Chieftalk for the same thread.... Link to comment Share on other sites More sharing options...
Ginger Posted June 14, 2014 Author Share Posted June 14, 2014 Thanks guys, this worked! Sooo simple, funny thing is that I looked into shapes, oh well... Link to comment Share on other sites More sharing options...
