Tapered Piers - how to
Ginger
Mark,
It appears from your photo that the piers are tapered on only one side.  If true, and depending on which version of Home Designer software that you're using, you should be able to apply a wedge from the shapes library adjacent to a soffit, box, or slab object.  You'll then need to apply an appropriate texture to each, and if the option is available in your software title, apply the textures with global mapping so they blend seamlessly across both objects.
Hope this helps. :)
