Sign in to follow this
ethanjsmith82
Ceiling structure vs floor structure
Why does the software allow me to set the "ceiling structure" of floor 1 to a different value from the "floor structure" of floor 2?  Does it just ignore one of the values?  The way it is displayed in the dialogs makes it look like, by default, you'd have a 2x6 ceiling and then a separate/additional 2x6 floor above that.
if there is a 2nd floor above it is ignored , but not every 2nd floor is the same size as the 1st floor ,so the setting is needed for those areas.
No, you were asking about the 1st floor ceiling structure , if it is needed it is used, but  if you have a 2nd storey above the 1st floor ceiling checkboxes are ignored and the 2nd floor structure settings are used, AFAIK.
