RDJunc Posted Thursday at 01:04 PM Share Posted Thursday at 01:04 PM Hi. I have designed a modest house that has a 48" second story that is finished inside. To do that, I had to turn off Auto Build Roof once I had the roof the way I wanted it. As you can see from the picture, I now want to add a detached garage. How do I work on the garage with Auto Build Roof turned off? I have Home Designer Architectural 2025. Thanks. Link to comment Share on other sites More sharing options...
RDJunc Posted Friday at 12:44 PM Author Share Posted Friday at 12:44 PM Well I sort of figured it out and sort of not. I was not able to work on the garage without turning the Auto Roof Build back on. It is always risky because things can easily blow up if I don't do things right. To get the roof connection between the garage and the house, I added a patio between them with a roof above. I had to match the heights and pitch but the overhangs made the final connection. The patio could not touch either building. Link to comment Share on other sites More sharing options...
