What is the default color spec for "drywall"
acerman
I happen to like the default color that Home designer uses for drywall.  I want to use and need the color in Sherwin Williams paint.
I can't locate any color definition for stock "drywall" on the site.  See attached.  The upper wall and ceiling color is what I am seeking spec on.
The lower walls are SW Alibaster
Any ideas?   I don't really want to go thru color palette trying to find a match.
**** McCord
Home Designer Pro 2024
Hey there,
You can select the material using the Adjust Material Tool which will open the Define Material dialog. Then, select the Material Color button which will give you the RGB value you're looking for.
If you used the Default Style when creating your plan and haven't modified the drywall material at all, then the color is RGB(239, 233, 218) which is Hex #EFE9DA
Best,
Connor
Thanks Conner.
After searching, I found the adjust material tool and was able to determine RBG on my particular drywall color to be 186179161 which I was able to match up with Sherwin Williams paint code.
Appreciate your help.
