Paulg2024 Posted August 5, 2024 Share Posted August 5, 2024 Hi there, I took a series of measurements of my existing building. I purchased Home Designer Pro, but am having troubles setting widths of my structure. It seams that the numbers do not change, or worse, modify the other measurements. Please see attached, as an example I am trying to enter the dimensions in the bottom 98, then 87.5, then (120+12+115+11.5=158.5) But have no luck as the walls are not taking my values. Also, how can I prevent the walls from automatically merging into one? This makes adding my measurements impossible house.zip Link to comment Share on other sites More sharing options...
Solution Paulg2024 Posted August 5, 2024 Author Solution Share Posted August 5, 2024 Ok I figured it out, I set the General Wall settings to Outer wall, and I clicked on the dimensions to resize house-fixed.zip Link to comment Share on other sites More sharing options...
