Locke_x Posted June 3, 2024 Share Posted June 3, 2024 I'm very new to this, so I apologize for the noob question, but I cannot find the answer online. I am making a lean-to type building and need to make one side shorter. I can easily change the thickness and length, but can't see the wall height. How can I do this? Also, any ideas why it wants to put the roof in the middle of the walls?Lincolnton2.plan Link to comment Share on other sites More sharing options...
Solution ConnorE Posted June 3, 2024 Solution Share Posted June 3, 2024 Hi Locke_x, You can change the height of a single wall by switching the wall out for a Straight Half-Wall. (More info can be found here https://www.homedesignersoftware.com/support/article/KB-02969/changing-wall-heights.html) It sounds like you're trying to make a Shed Roof design which is much easier to achieve with our Automatic Roof tools. Here's a video to give more information on that if that's what you're looking for! (https://www.chiefarchitect.com/videos/watch/6125/shed-roof.html) Best, Connor 1 Link to comment Share on other sites More sharing options...
Locke_x Posted June 4, 2024 Author Share Posted June 4, 2024 21 hours ago, ConnorE said: Hi Locke_x, You can change the height of a single wall by switching the wall out for a Straight Half-Wall. (More info can be found here https://www.homedesignersoftware.com/support/article/KB-02969/changing-wall-heights.html) It sounds like you're trying to make a Shed Roof design which is much easier to achieve with our Automatic Roof tools. Here's a video to give more information on that if that's what you're looking for! (https://www.chiefarchitect.com/videos/watch/6125/shed-roof.html) Best, Connor Thank you so much!! That helped immensely! That one and the following one (in case anyone else has the same problem) helped get my problem fixed https://www.homedesignersoftware.com/videos/watch/2237/automatic-roofs.html?playlist=200 1 Link to comment Share on other sites More sharing options...
