Issue with the sizes of the auto room specs produced when assigning room labels example "Bedroom" "Garage"
Aspyre263
I’ve created a room with dimensions using the interior dimension tool. I assumed it measures from wall to wall, surface to surface, which is what I want. I’m trying to build a plan based on our builder’s vision plan, which I have as a PDF. However, when I assign labels like ‘garage’ or ‘bedroom,’ the measurements don’t seem accurate. It’s showing 4,474 by 5,474, but when I inserted the interior measuring tool, it showed 4,500 by 5,500, which is the size I’m aiming for
Dims you have if you look close at what arrows point to are normally the STUDs not the interior or exterior surfaces.
So if the dims you are looking at on paper plan are from interioryou need to subtract sheetrock thickness times 2.
The dims under room are from interior surface and well not meant for building from but just to give an idea since it shows MAX dims which if you have a dogleg in room makes it funky
