Lesstephenson Posted March 12 Share Posted March 12 Trying to place a rug, however once I select the rug the material painter seems to be the default (not select object) which ends up covering my entire floor with the rug. How do I get out of the material painter? Link to comment Share on other sites More sharing options...
y-g-m-n Posted March 12 Share Posted March 12 where are you when you first select rug? 2d or 3d world? Ned to set something down on floor first torepresent rug in 3d and then "PAINT" rug you want onto it. I have used shelves and 3d boxes and set dims to whatever rug is say 48"wide x 72" long x 3/8" thick and then set bottom elevation to 0" above floor. Link to comment Share on other sites More sharing options...
Lesstephenson Posted March 12 Author Share Posted March 12 In 2D I can't seem to place a rug. I select the rug then try to click it into place and nothing happens. If I use 3D the material painter is the default. Link to comment Share on other sites More sharing options...
