Quick solution to blurry, low resolution elevations and sections sent to layout sheet
DanatCV
I was having a problem with very blurry, low resolution elevations and sections sent to the layout sheet as a scaled, updateable item.  If that happens to you, here is a quick fix:
Select the low res item on your layout sheet, zoom in close, and then click on the "Update Layout Views" button and your problem should go away.
I hope this helps someone before they waste as much time as I did figuring this out.
Cheers!
