Xtropy Posted May 25, 2022 Share Posted May 25, 2022 I've been struggling for years getting stairs to work on my split level. I just tried out the new version of 2023 hoping they made some improvements but still stuck in the same area (using Architectural). The issue is the stairs keep stopping at the top of the crawl space and not at the top of the second floor. In 3d, I get all these weird parts where the walls from the levels join but I have no problems like this anywhere else in the house. Any suggestions/guidance on what I can do to fix them? Link to comment Share on other sites More sharing options...
Xtropy Posted May 25, 2022 Author Share Posted May 25, 2022 9 minutes ago, solver said: Stairs go where you draw them. What is "keep stopping"? The view with the missing walls shows the steps stopping below the actual floor. Maybe it's nothing but just something I noticed. I believe the missing walls are coming from the upper floor but not sure how to get them to extend down all the way and make a proper joint with the lower level. Everything is aligned in reference view, just stuck here... Thanks anyone that can help fix this issue or assist me in doing so Homelands - Interior 1st and 2nd - With Paint - Stairs WIP - 2023.plan Link to comment Share on other sites More sharing options...
Xtropy Posted May 25, 2022 Author Share Posted May 25, 2022 That was extremely helpful thank you very much. Just something as simple as moving that hidden wall was all that I needed Now to try and figure out why the walls are missing in those two spots i agree that split levels are a pain in Designer thanks again for your help and time Link to comment Share on other sites More sharing options...
