at2garcia Posted April 15, 2022 Share Posted April 15, 2022 Hello, I am using Design Home Pro 2022, and i would like to create a floor that represents the floor my home has now. The floor that divides my 1st floor from the second floor is made up of the subfloor, joists, acoustic batt, Hat channels, and 2 layers of 5/8 drywall. picture provided. Am I able to do this in Home designer PRO? Thank you. Link to comment Share on other sites More sharing options...
atomic23 Posted 14 hours ago Share Posted 14 hours ago See that your question is three years old...I will need to do the same thing and curious if you found a solution. I have not used the Home Designer Architectural 2025 much, yet. Link to comment Share on other sites More sharing options...
