jarrex Posted January 28, 2022 Share Posted January 28, 2022 I have a dormer that needs to be above the stair railing, however when I manually create the wall, the railing cuts the roof siding wall in half which creates an odd hole in the roof: The interior is fine But I know it's the railing that's causing the issue because if I delete the wall that gets cut after the railing the hole disappears (but then the siding isn't filled in) Any ideas as to how to fix this? Link to comment Share on other sites More sharing options...
