ThomasWilder Posted December 5, 2021 Share Posted December 5, 2021 Hello, I am trying to find the best way to model a Georgian window, with an angled inset into the wall's thickness, and a window along the inner edge (see the attached image). Note that this isn't a box window - there is no "bump out" - the window is set into the wall. I thought about using a wall niche, but I do not know how to create the angle. Any suggestions would be greatly appreciated. Software version: Interiors X13 Link to comment Share on other sites More sharing options...
ThomasWilder Posted December 7, 2021 Author Share Posted December 7, 2021 Hi Eric, Thank you, I now am actually using HomeDesigner Suite 2022 (I was just using a ChiefArchitect trial), so I will leave this here. Thank you for your response on ChiefTalk. Would you be able to tell me how you made that visual (attached)? It is exactly what I need. Many thanks Link to comment Share on other sites More sharing options...
