beauganas Posted November 10, 2021 Share Posted November 10, 2021 Hi, I'm trying to create a roof on a 1.5 story project. In the attached example, the gable's roof starts about 24" above the floor of the second story, while the left side of the house' roof essentially starts right above the walls of the 1st floor (ignore 2nd floor walls option, essentially). How do you do such a thing in HD Pro 21? Should you: 1) Create second story 2) divide with interior wall 3) set ceiling height of higher section to be 24" 4) Build Roofs checking "Ignore 2nd floor walls" 5) reset Structure-> Finished Ceiling height to default. Would that work, or is there a better process/method? Thanks! Link to comment Share on other sites More sharing options...
beauganas Posted November 10, 2021 Author Share Posted November 10, 2021 Thanks Eric. I turned the signature on...hopefully it shows. Link to comment Share on other sites More sharing options...
