Sellers Posted January 10, 2021 Share Posted January 10, 2021 Desire: Take an imported object, and copy the texture/material/color from part of that object so you can use it on another object: Ex: I can import a roof design from a manufactures color pallet on 3d-warehouse and take the "green" roof color from the pallet and add it to my library so I can apply that roofing to my structure Steps to do this: 1) place the object in your plan It will be a 2d object probably 2) in 3d mode, select that object and right/ctrl click on it. 3) Choose "find original in library..." which it will not (unless you have it, and then viola you are done) 4) A dialog allowing you to pick the item you want to "pull" from that to add to your material library by selecting the checkbox; press OK . You should see it added to your User Catalog 5) Select another object in your plan, the one you want to have the material applied to; and select the new material from the material browser. I hope this helps others find out how to take imported materials and apply them to your objects... Home Designer Architect 2021 MacOS Link to comment Share on other sites More sharing options...
