Chrisw1 Posted August 6, 2019 Share Posted August 6, 2019 I am trying to design "tiny home communities" that fit into existing in town lots <1acre. My tiny homes are already designed and just need to be positioned on the lots based on setbacks, space utilization, site design, etc. Are there are resources that show the best way to do this? Specifically, I have not been able to figure out how to: - Freeze/lock lot lines so you don't keep moving them accidentally when moving the houses - Freeze/lock setbacks so you don't keep moving them accidentally when repositioning the houses - Convert a home into an object do I can be easily moved around a site plan I am using Home Designer Pro on a Mac. Link to comment Share on other sites More sharing options...
Chrisw1 Posted August 6, 2019 Author Share Posted August 6, 2019 Ok. Does that mean I'd have to work in both versions to create a single site plan with designed homes? Link to comment Share on other sites More sharing options...
