55145514 Posted November 16, 2014 Share Posted November 16, 2014 I just got pro 15. I can use the ICON line to select and place doors & windows. I needed a 1/2 rd. window, I found then in the library, put I can't move them out of the library section. I can rotate them in the library window put they will not move to the plan. What am I doing wrong??? thanks, Bill Link to comment Share on other sites More sharing options...
Kbird1 Posted November 16, 2014 Share Posted November 16, 2014 make sure the Selection pane is open in the library view along with the Preview Pane , click on the selection window once a window is chosen, then click on the wall where you want the window to go. 1 Link to comment Share on other sites More sharing options...
55145514 Posted November 16, 2014 Author Share Posted November 16, 2014 Thanks, I was trying to place it in 3D, and could not get that to work. I tried it in 2D doing as you said and I can place it. Thanks you, Bill Link to comment Share on other sites More sharing options...
