horizon_cr Posted October 20, 2014 Share Posted October 20, 2014 Hello, Is there any way to cover a wall with more then one material/design?. For example: Tile a shower that the bottom half of the wall is tiled straight, and the top half is tiled diagonal. Or 2 different tiles for the same wall (1 for the bottom half, 1 for the top half) Thank you Link to comment Share on other sites More sharing options...
Kbird1 Posted October 20, 2014 Share Posted October 20, 2014 Wall Covering will do the 1/2 and 1/2 wall no problem but you may need to copy a material and rotate it 45°deg if the tile you want at a diagonal isn't already in the Library. the Process for adding it to the wall is the same though . At least it works in Pro which Eric and I both have, your sig doesn't state your Title or version and they all have different features Link to comment Share on other sites More sharing options...
