rfcomm2k Posted September 19, 2014 Share Posted September 19, 2014 Have a pole barn structure in which I have added 2 small rooms, a bathroom and a foyer at the rear of structure. Original structure has no ceiling but the ceiling height is 180 1/2". At rear the ceiling height is 130 1/8". The two rooms are to be framed with 8' walls. When I drew the interior walls as needed, one wall extended the full height to the roofline. The other walls remained at the normal height. I then clicked inside each room and tweaked the ceiling height and checked the Ceiling over this room box and added a 5/8: ceiling finish. The space above the ceiling will be used for storage. In camera view the ceiling is missing. I checked the display options and everything needed to display a ceiling is checked. So, why did the first wall extend itself all the way to the roof, and why is the ceiling missing? Is this yet another case in which I will need to manually place framing members to "simulate" a part of the structure that should (in my opinion) exist already? Link to comment Share on other sites More sharing options...
Kbird1 Posted September 19, 2014 Share Posted September 19, 2014 because it assumes you want walls at the same height as the existing walls/floor defaults , normally if you know you want a mezzanine floor you build the structure as a two story structure with an open below area on the second floor where you want the two story height . you will find other posts here is you search mezzanine but here is a KB Article too: http://www.homedesignersoftware.com/support/article/KB-00210/ M. Link to comment Share on other sites More sharing options...
