Dreamscape Posted January 15, 2017 Share Posted January 15, 2017 Good afternoon I just found out that I can't edit the height of the floor joists / ceiling structure Should I be able to see the Rim Joists in 3D Framing view or is this deliberately invisible in Architectural 2015 Thanks Link to comment Share on other sites More sharing options...
Dreamscape Posted January 15, 2017 Author Share Posted January 15, 2017 Using Home Designer Architectural 2015 They're disabled in the screenshot you are showing. But I'm surprised that they are missing from the 3D Frameview Link to comment Share on other sites More sharing options...
Dreamscape Posted January 15, 2017 Author Share Posted January 15, 2017 The joist size is set to 125mm which I would say is not really to any code- and can't be changed Link to comment Share on other sites More sharing options...
