eganders Posted August 27, 2014 Share Posted August 27, 2014 I built a fireplace using stacked stone. It extends out to the outside of the house (the firebox "bulge"). I understand that the material specification for the fireplace can only be one material, so how do I show that the outside of the house "bulge" of the fireplace is another material, such as the external brick on the house or a specified material other than the stacked stone? I can't use 2D boxes to cover it and a wall specification does not seem appropriate. What is the best way to cover the stacked stone "bulge"? Link to comment Share on other sites More sharing options...
Kbird1 Posted August 27, 2014 Share Posted August 27, 2014 Keep the Fireplace Flush with the Ext. Wall , and build the chimney/chase separately wide enough to cover the "bulge". Then apply whatever material you like to it. Instead of using the Fireplace tool there are Fireplaces in the Library , eg Rustic Fireplace 1 and 2 which are architectural blocks which can be then exploded and a different material assigned to the Chimney/brick material in the "bulge" ( or any of it components) M. 1 Link to comment Share on other sites More sharing options...
