VAsher Posted August 8, 2014 Share Posted August 8, 2014 Hi Everybody, I am using HD Pro 2014 I created a home, garage, and did the landscaping; then added a garden shed. The house foundation has about 24" above ground. So my shed is floating the same height above the ground. When I try to do any editing on it it affects the house.....! What am I doing wrong? Thank you... Link to comment Share on other sites More sharing options...
Kbird1 Posted August 8, 2014 Share Posted August 8, 2014 There doesn't appear to be a foundation on the Shed which is why it looks as though it is floating , and you see the white hole in the ground where HD is expecting one. Rather than rebuild the foundations ( you'll lose all work in house basement) try designating the Shed in it's Room DBX a Porch ,which should give you a 4" concrete floor ,you will probably then need to adjust the Floor height in the Room DBX too eg -14.5" approx. , this is because typically a house with a stem wall foundation is about 18 1/2 " about the ground. You could check that in the Terrain Perimeter's DBX in the building pad box>pad elevation. Mick Link to comment Share on other sites More sharing options...
Solution VAsher Posted August 12, 2014 Author Solution Share Posted August 12, 2014 Thank you Mick, I had to fool around with the ceiling too but in the end it all worked Thanks so much... V. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 12, 2014 Share Posted August 12, 2014 glad I could help . Mick. Link to comment Share on other sites More sharing options...
