Ursula2015 Posted October 6, 2015 Share Posted October 6, 2015 Is there a way to increase the depth of a (42" high) corner wall cabinet from 12" to 15"? This is typically needed when the adjoining wall cabinets are shorter (30" or 36") and of standard depth (12"). The crown moldings of the shorter cabinets would 'die into' the side of the deeper corner wall cabinet. I'm using 2016 Premier. Thanks in advance! Link to comment Share on other sites More sharing options...
KirkClemons Posted October 6, 2015 Share Posted October 6, 2015 Assuming you are working with Home Designer Pro 2016 or Chief Architect Premier, you can open the cabinet up and change it's left and right widths to change the overall depth. Link to comment Share on other sites More sharing options...
