How to put roof on a bump out
Fourlakes
Hi,
I'm trying to design an exterior that has a gas fireplace bump out thats only 6ft high and would like it to have a shed roof on the side of the house. I'm having no luck putting a bump out thats defined shorter than the outside wall height let alone trying to get a roof on it.  Any help or ideas would be appreciated. Thanks you!
Please add your name and software version to you profile sig ( see mine below for a how too ) so we know who you are and what you are using as they have different capabilities and thus different answers.
However , if you make the bumpout a separate room (room divider? ), give it a height of 6ft and tell the Bumpout's (3) wall's Roof tab to make a shed roof  ( check how to make basic roofs)  it should work fine.
