hitya723 Posted July 3, 2015 Share Posted July 3, 2015 I would like to change the exterior and interior side of the windows because the glass should be at the interior side instead of the exterior side. The program places the glass of the windows closer to the extetior side. Can you help me? Link to comment Share on other sites More sharing options...
Kbird1 Posted July 3, 2015 Share Posted July 3, 2015 What type of window ? I'm not sure that is possible as windows auto locate in walls ,you can change the Sash Inset measurement in some Versions of HD though. You could try a different Window Manufacturer's Library, instead of the default HD built in ones perhaps.... M. Link to comment Share on other sites More sharing options...
hitya723 Posted July 3, 2015 Author Share Posted July 3, 2015 Thank you, I've solved with changing the sash Link to comment Share on other sites More sharing options...
