LeeNicholson Posted June 22, 2015 Share Posted June 22, 2015 I am trying to add a shed roof over a front porch and also a back deck/screen porch. When I do the 3D view it only looks like a deck with railing on both front and back, therefore I an unable to get a roof because there is nothing to support it. How do I extend the railing timbers to support a roof. I have attached the plan so someone can see what I did wrong. I am using Home Designer Suite 2016 Whiteoak Cabin.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted June 23, 2015 Share Posted June 23, 2015 you likely need to turn on the Roof ,and perhaps the ceiling in the Deck and Porch Room DBX , and the Railings will need to be set with Post to ceiling or Post to Beam on their Wall DBXs. I'll take a quick look and post back if something else is going on. M. Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted June 23, 2015 Solution Share Posted June 23, 2015 You hadn't set the Roof Pitch in the front Railing wall of each Deck to something low like 2-3° either and each end railing wall needs to be set to Full Gable to get a shed Roof in the Wall's DBX Roof Tab too. I see you have stairs going up so I built the 2nd floor , for two reasons so you will get a proper stairwell and so that you can make Rooms on the @nd level even if it is only an Attic Space as HD software doesn't allow you to do anything on it's own Attic level , so you have to make a 2nd Floor and then make the ceiling height 0" if needed so you get a Floor up there and can make Rooms etc. as you can see in the pic I left the 2nd floor at 8' as I don't know your real height. Though it is likely you will need some height otherwise the Roofs will meld together , in which case it could be done with a Gull Wing roof too I think in this situation. M. 1 Link to comment Share on other sites More sharing options...
LeeNicholson Posted June 23, 2015 Author Share Posted June 23, 2015 Great, thanks for the tips. Still learning. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 23, 2015 Share Posted June 23, 2015 Sorry should of said DBX = Dialog Box here on the forum since you are new... Link to comment Share on other sites More sharing options...
