snuggarelli Posted June 1, 2015 Share Posted June 1, 2015 So, this is a dumb question. Working on a two-story house. Every time I insert a piece of furniture from the library into a room, it just disappears. I tried toggling layers, and it only switches between floors and labels of floors. Help - I'm losing my mind. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 1, 2015 Share Posted June 1, 2015 a particular piece? or all furniture? in which case I'd say your Furniture layer is off. ......reading your post again I'd say you are checking layers for the ROOM not for Furniture , so don't select anything and open display options and scroll down to furniture,interior , it should have the red cross hopefully , check the DISP column and you should be good to go. otherwise post the plan , see my sig. for a how to if needed. Link to comment Share on other sites More sharing options...
eraser Posted June 4, 2015 Share Posted June 4, 2015 Your imported furniture has a 0" to ground setting. Change the setting to the dimension height of the 2nd story floor. When importing furniture, I placed it outside on the ground. Then I set the ground to bottom dimension in the "Open Object" menu and moved the furniture into the room. Link to comment Share on other sites More sharing options...
