DaveProsser Posted May 22, 2015 Share Posted May 22, 2015 I have an interest in Chief Architect Home Designer Professional, but need to know if it's possible to create tooled timber columns and inserted Glass Panels (see the attached .PNG file. I created this image using Autodesk Inventor, but this is not an idea programme for creating Architectural design work. Regards Dave Prosser Link to comment Share on other sites More sharing options...
Kbird1 Posted May 22, 2015 Share Posted May 22, 2015 easiest way to find out would be to download the Free Trial and play with it , only restriction is you Cant save files till you activate it https://homedesigner.chiefarchitect.com/products/trial.html HD Pro can import 3D Models off 3D Warehouse and from other sources too but making 3D Models is limited , you'd need Chief for that. M. Link to comment Share on other sites More sharing options...
