PaulJ33 Posted August 13 Share Posted August 13 Hello, When I choose a camera view to see my content in 3D mode, I first see a black screen with 2 large arrows pointing to the 2 o'clock position of screen, one on top of another. It sometimes flashes to where I can see 3D mode for a brief second and then nothing onscreen, only white background. This also occurs at startup of Home Designer. The option area is black screen with the 2 arrows. I tried downloading the program again and re-installing, but no difference. Could this be a driver problem? Never did this before. I have Home Designer Pro 2021. Thanks for any info. Link to comment Share on other sites More sharing options...
Solution PaulJ33 Posted August 14 Author Solution Share Posted August 14 Solved the issue myself. The problem was the video driver. Even though updates were telling me that I had the latest and best driver, this was not the case. I went to NVIDIA and manually downloaded the latest driver. The black screen and what I thought were arrows that I saw, was part of an NVIDIA backdrop. Once I installed new driver, everything was fine. Link to comment Share on other sites More sharing options...
