Unable to show arrow on my stairs
ViaRivera
I have a L-shaped stairs and need to show the up arrow.  No matter what I try, the arrow is not being displayed on either section of the stairs.  Any suggestions on what I may be missing?
HD Pro 2025
Edited by ViaRivera
Edit
2 things to check.
In the STAIR edit Dialogue - Tab for ARROW - Check box for include ARROW at top.
Then on main menu TOOLS go to DISPLAY OPTIONS
Scroll down to STAIRS & RAMPS, UP/DOWN Arrows and make sure you have a Check mark under DISP Column to turn it on in whatever view you are in.
Most things are pretty simple it is just finding them..
So if you cannot see something see if it is turned OF in the display options.
IF on there go to item and open its edit dialogue as normally everything you need to edit item is in there.
