NewbieTed Posted November 21 Share Posted November 21 I am fairly new to HD. I would like to use a different shape for the top rail for the stairs and the railings around the stairs. I also would like to make them a dark brown while the balusters are white. The posts are dark brown as well. I assume I look in the library, but I am not sure that shape is in there and how would I assign it to top rail? Link to comment Share on other sites More sharing options...
solver Posted November 21 Share Posted November 21 1 hour ago, NewbieTed said: I assume I look in the library, but I am not sure that shape is in there and how would I assign it to top rail? Find a molding profile in the library -- look in (download) bonus catalogs too. In a camera view, click the molding in the library, then click the object you want to change. Painting (or staining) works the same, or select the object, open it and change in Materials. Link to comment Share on other sites More sharing options...
Rookie65 Posted November 21 Share Posted November 21 If you go to the bonus catalogs, under millwork, there's a catalog for purchase called Handrails No01 fittings. In there are several styles of handrails which you can select from. Then follow Solver's direction to apply it to the handrail. Link to comment Share on other sites More sharing options...
Jo_Ann Posted November 22 Share Posted November 22 Follow the advice given and you can get this. Link to comment Share on other sites More sharing options...
NewbieTed Posted November 22 Author Share Posted November 22 thanks you guys. I will give it a go. Link to comment Share on other sites More sharing options...
Jo_Ann Posted November 22 Share Posted November 22 Oops, I should have left the balusters square. Link to comment Share on other sites More sharing options...
