Small roof satellites??
Robborito
Experimenting with the auto roof tool - When wall intersections on plan are of an acute angle - these small satellite wedge style hip roof appear on the basement plan?
See my attached image.
They are easily deleted - however strange they should appear?
Is there a radio button on the basement plan that prevent this?
I can't seem to find one.
I know all of this is simply done using the manual roof tool - however the auto tool is a handy thing - although has some limitations.
Are there some rules I need to know - that are not that obvious?
Thank you HD Pro world.
Thank you for your input.
Walls are good on both levels. The intersections are generated automatically - and tight.
Is see it as the pony wall being treated as two skins.
The little satellite roof - is for the lower brick outer wall of the pony wall.
The cavity in the wall at the acute point is much larger thru its truncation in plan. ( Are you with me )
It appears in two locations in my screen shot - exactly the same result. Acute wall intersection angles.
Large cavity's - maybe read as a void or hole...I don't know.
I have tried it several times - same result.
Maybe not that simple?
I've worked around it - just deleting them, no big deal - but......why does it occur.
